RCU Forums - View Single Post - problem with balde cp controller
Old 11-04-2005 | 04:56 PM
bluesky123
Default RE: problem with balde cp controller
Please read my previous message carefully: the channel mixing is done in the transmitter itself! Id doesn't matter what you are flying in the simulator, planes or helies. If the channels come to the sim already mixed, the sim can't do anything...
In other words, Blade CP transmitter can only be used with this particular helie. It has CCPM, which you can't turn off to fly a fixed wing plane or to use this TX with a simulator (unless you get a CCPM "unmixing" interface).
The only fault of LHS people would be if they don't explain this to you when selling the transmitter.
