RCU Forums - View Single Post - Car set up tips.
Old 11-04-2005 | 07:14 PM
kx250ryder's Avatar
kx250ryder
Default RE: Car set up tips.
ORIGINAL: GRANT ED
. . . I believe the rear shocks need lighter oil as the back jumps around a bit in the rough stuff. . .
Too stiff of springs, too small of shock piston holes, or too stiff of swaybars could cause this as well.
ORIGINAL: GRANT ED
My car also seams to be very tail happy under power I was thinking of changing the diff oil (5K,7K,1K at the moment) but am not sure. Any suggestions?
Thinner rear diff oil may cure this. Softer rear suspension/stiffer front suspension could do the same by limiting weight transfer. Softer clutch springs could also aid in more controlled acceleration.
EDIT: Look to the opposite end of the car first to correct the problem. Car setup is a game of weight transfer. If your rear end is loose, try tightening up the front end. If the rear end acts too stiff, try correcting by stiffening the front. I don't know if they make thinner diff oil than 1k, so you may have to look for other alternatives to solve your on power acceleration issues, including perhaps different tire selection. Fewer/taller knobs for soft loose soil, more/smaller knobs for firm packed soil.
