RCU Forums - View Single Post - Why balance upside down?
Old 11-05-2005 | 01:17 AM
ryanpilot's Avatar
ryanpilot
Default RE: Why balance upside down?
Yes it does make a differance. If you try to balance right side up (wheeles down) on a low wing plane it can cause you to balance wrong and end up with your weight all screwed up.
Try this. After balancing the recommended way (wheels up) then flip it over and see how it balances. Depending on the plane you will see that it acts like it is out of balance.
