RE: cg question?
Lowering the engine won't have an effect on the CG. Most trainers have the tank mounted lower than ideal. It has and tendency to richen the engine setting when flying inverted (not likely in a trainer). I would suggest flying the plane as it is making sure the CG is in the correct position and the plane is also balanced laterally (from wing tip to wing tip).
EXCAP232
