RE: Tam smoke system installation
Steve,
Here are a few shots of the TAM system on my KC. It's an AMT but would be similar to the JetCat. I have found one of the secrets is to pinch the ends of the nozzles to get a finer spray of the fluid.
You can mount your smoke tank in the cavity aft of the main tanks. Believe it or not this is just about on the CG. 40oz will give you 3 or 4 minutes of good smoke but the cavity will hold a 50 oz tank.
Craig
