ORIGINAL: NJAIRSTRIKE
I'm still having trouble finding a spinner that would fit a 14X6, 14 X 4 W, 15X6 Props. Please help. Is there any links of spinners maybe even true turn that will work with this. Thanks
No matter what prop you are using it's difficult to find a spinner that fits correctly. It's a fact of life in this hobby that you're going to have to trim a spinner to fit properly on given prop. Just make sure that when you trim it up that the spinner isn't touching the prop as this can cause the prop to fail when the engine is running.
Hope this helps
Ken
