Rolling Harrier Hints n Tips
Hi guys,
I was trying to practice some rolling harriers with my Fliton Jumping Jack. My aileron deflections are about 45-50' on the 3D mode. Well it starts really smoothly and relativelly fast to the harrier roll, bus as speed is reduced that kind of smoothness goes away.
I know that the trick is to play with throttle by giving bursts this is what I do on the sim and with my IC engine models to retain constant roll rate. However in this case it seems that throttle bursts are not very effective. Those ailerons act as air breaks for sure would you recommend to reduce the deflections a little bit?
Any recommendations are more than wellcome.
Nick
