RCU Forums - View Single Post - morane-eindecker thingy
Old 11-06-2005 | 10:55 PM
  #33
67ccmustang's Avatar
67ccmustang
Default RE: morane-eindecker thingy
THe rear strut supports the wing-warping wires bell-crank assembly. I have the two struts attached to a short length of brass tube, which is embedded into the plywood fixture and the struts are soldered to it as seen in the picture. This strut was so easy, less then 30 minutes to do, very easy because all the dimensions are true in one plane.
ID:	350047   Click image for larger version
ID:	350048   Click image for larger version
ID:	350049   Click image for larger version
