RE: Genesis Arf Build (Electric)
Oh that brings up an interesting question... Does this plane have foam layering sandwiched in the fuselage? I swear Im seeing a honeycomb like styrofoam when Im looking inside the fuselage with light penetrating from the outside. Are you using that foam safe CA for that reason? Yikes, if so I will break out my foamy repair kit if I need to tack anything to the fuselage.
