RCU Forums - View Single Post - Genesis ARF build, glow version
Old 11-07-2005 | 04:48 AM
  #58
MikeEast's Avatar
MikeEast
Default RE: Genesis ARF build, its here.
I just found something out that those of you reading may not know (and I did not know) about the Genesis that I got from Bills thread over in the electric forum. The fuselage is made of a composite with a foam layer sandwiched in between. If you are going to use any CA when tacking things to the fuselage itself, you need to use foam safe CA. Especially if you use accelerator, it will burn through and melt the foam.. Yikes, Im glad Bill mentioned it..
