RCU Forums - View Single Post - Turbine help
Thread: Turbine help
Old 11-07-2005 | 09:23 AM
joeflyer
My Feedback: (49)
Default RE: Turbine help
Who replaced the bearings? Normal proceedure is to to rebalance the engine when bearings are replaced. As long as the check up and bearing replacement was done by someone competent you should be good to go. If it was done by RTI or Modellbau I'm sure you are OK.
Joe
