RE: 46FX---AX help
Breaking in with the stock muffler is best because you can't lean the engine to peak RPM until it's had some running times. If the pipe's not tuned correctly, you may wind up with a too-lean run.
When you change to different engines, you usually have to retune the pipe system. IF the new engine is runing th esame RPM, then maybe not.
