RE: RX and TX compatability
Turk its a good question. Yes that flight pack described by you will work fine. The modulation type in your Tx must be set for PPM. If your Tx was obtained through the north American market you would set the Rx's modulation shift for negative shift. If your Tx was obtained through other world markets its may possibly be a positive shift version of Futaba and in that case you would set the Rx for positive shift.
Enjoy
John
