RE: Vectorflight Edge 540 build
It must be thicker than ultraKote or MonoKote...Isn't it a hard "Shell" to protect the dead soft foam?
I mean you can't dent the wing with a fingertip...or easily just plunge a t-pin through the wing using only the same light pressure you would use to push a t-pin into a chunk of foam...Or can you....
My plane hasn't arrived....and I'm sure I would say "Duhhhhhh" if I had the wing right here..
Thanks for the info.
Larry
