I need some good advice here guys....I just bought my first LiPo battery (I know, I`ve always been a slow learner) it`s a 3 cell Thunderpower 1320. It has 2 main leads and a 4 pin Balance connector. I called Thunderpower to confirm that it`s charged and discharged through the red and black leads. It doesnt have a connector yet, so this is my question...The Blade CP uses JST connectors, Would it be a good idea to just solder a male JST onto the battery, or install the small ultra dean on the Heli and on the battery? I`m hoping to also use this battery in my foamie so I will need to standardize. What are most of you using as far as connectors and Lipos on your BCP`s? I will be picking up a Triton this weekend, so I`m sure There will be alot of questions in the Battery & Charger Forum. What kind of flight times should I expect? and what`s a good rule of thumb to quit flying before I discharge below the 9.9 minimum?
Tanks!!!
