RE: Vectorflight Extra 300S Throws
greg
I put my 300s 66" together last summer and if I remember I used an incidence meter set in the middle of the elevator span. I fly on high rate elevator and it works fine--never had a problem with snapping at any speed. I probably set the rudder the same way and have no problem holding knife-edge flight. I do not have dual rates on my radio for rudder.
This plane flies where you point it and I doubt if a small variance in the settings will make a noticeable difference for sport flying. THis is my favorite plane and it will probably be yous too.
jerry
