RE: RX problem fixed now-
I changed to nylon clevises on the engine end of the push rods,changed throttle servo,added voltage regulator to reciever,and did away with extension,moved the matchbox as far away from all electronics as i could,also moved the ignition and battery to the outside of the motor box instead of inside.
