RCU Forums - View Single Post - Avistar Wing Rod
Old 11-08-2005 | 06:11 PM
desmobob
Default RE: Avistar Wing Rod
ORIGINAL: trekkerguy
Yes, the RTF has the metal rod, but the ARF does not.
So, does this mean that when I take the dihedral out of my spare Nexstar wing that I don't have to put in the rod? Hope it does.
And, thanks folks for your input.
No! You have to have something in there... the rod or a plywood joiner. Since the wing is set up for a metal rod, there is no pocket for a plywood joiner. It may be difficult to try to remove some of the dihedral. I guess you'd have to add some wedged ribs at the root ends of the wing and carefully bend the metal rod to fit the new wing shape?
Others here will have the correct information for you.
Good flying,
desmobob
