ORIGINAL: jdmintegra18
i did what that page said..still nothing...i kep richen it up from the 3 turns out and it got to 285..and cut off and wouldnt start again sounded like it wanted to...i also see air bubbles in m fuel line..what could be the cause of that..tank not sealing correctly???...when i hit the gas the engine is reved high but not moving...i was thinking the clutch is slipping..so i took the motor off and the clutch bell is real shiney..so it was slipping..im sure that will pick it up alil bit....i took the head and buttton off it had some scorein on the side of the cynd wall at the top...and im on my 4th tank....*** i havent let it get above 280...poorly designed engine....im thinking about getting the picco .27 and trying that..lemme kno your input
Replace all fuel lines and check the filter for leaks.
Air in fuel = hot and irratic running engine.
