RCU Forums - View Single Post - Avistar Wing Rod
Old 11-08-2005 | 06:43 PM
britbrat
Default RE: Avistar Wing Rod
ORIGINAL: desmobob
Since the wing is set up for a metal rod, there is no pocket for a plywood joiner. It may be difficult to try to remove some of the dihedral. I guess you'd have to add some wedged ribs at the root ends of the wing and carefully bend the metal rod to fit the new wing shape?
Others here will have the correct information for you.
Good flying,
desmobob
It is quite easy to do by bending the metal rod. Yes, you have to fill the gaps.
The more difficult & time consuming method is to cut slots in the end ribs for a wooden joiner, but ultimately, that method results in a lighter wing. As I said -- your choice
