RCU Forums - View Single Post - Thrust Angle for an Up & Go
Old 11-06-2002 | 09:09 PM
wildblueyawner
Default Thrust Angle for an Up & Go
Given the thrust line of an Up & Go high above a glider's vertical CG location, a nose-down pitching moment will be created, stronger than what a conventionally-mounted motor would generate.
Will increasing the downthrust angle effectively increase the angle of attack, in order to compensate for the pitching moment?
