RE: Jumping Jack Set Up for 3D
Hey Josh,
Can you please provide me you setup on JJ? Throws,expo,CG location,mixes etc.
Do you use any spoileron mix during harrier? I have a slight wing rocking problem and think of trying to resolve with spoileron. If I use spoileron for both upright and inverted do you think I should have it enabled during the harrier roll? What percentage would you advise, is 50% ok you think?
Also at full aileron throw 45-50' the plane starts the rolling harrier pretty fast and smoothly and then as speed is reduced that kind of smoothness goes away. I give bursts of throttle without good result. Do you think I should decrease my aileron throws a bit. It seems that those ailerons act as air breaks. What is your max throw during the harrier roll?
My plane flies ok but could perform better I think. It has come around 650gr with 2000mAh 3s Kokam batteries. I think it's too heavy for good 3D that's why I have those wing rocking problems. Also I moved my battery over the main spar, canopy area in order to balanace it vertically but it still drops the nose during hover, this battery is really heavy I think,it is nearly 160gr.
I hoped that I would manage this plane more easily than my IC models but it seems harder. I can hover and torque roll my 3D fun fly engine models for ever, JJ seems a bit more difficult to me and I believe something is wrong with my setup.
Looking forward to your answer, any further advice is wellcome.
Rgrds,
Nick
