RCU Forums - View Single Post - Spinner Assembly Came Apart While Engine On!
Old 11-07-2002 | 06:36 PM
BalsaBum
Default Spinner Assembly Came Apart While Engine On!
Your prop loosening may be due to the spinner backplate sliping against the base washer. This can be solved by drilling a small hole thru the spinner back plate and the base plate and inserting
a pin thru both of the appropriate size. This stops the "clutch effect" of so many surfaces relighing on friction to hold things together. Some blue locktite on the prop shaft helps too.
