RCU Forums - View Single Post - Spinner Assembly Came Apart While Engine On!
Old 11-07-2002 | 12:43 PM
Giant Scale
Default Spinner Assembly Came Apart While Engine On!
On my .46LA I added a lockwasher under the nut and have not had a problem since. My spinner would also loosen especially when using one of the nose weights. A little loctite may also be helpful. You could also use a second nut if the shaft is long enough.
