Spinner Assembly Came Apart While Engine On!
I will presume that you are using a non- wood prop
I don't use a torque wrench , but I really crank the
nut fairly hard.
If you use a wood prop , (I prefer them)you MUST
check it before every flying session ,it will be loose
because the wood compresses.
What you experienced is why you shouldn't be in the
prop arc.
Regards
Roby
