RE: Visibility issues
I have found yellow is the easiest color for me to see in all lighting conditions. I also like to have a wide stripe from the leading edge at the fuselage to the outer tip of the trailing edge that forms an arrow pointing forward on top of the wing. For the bottom of the wing, in addition to using contrasting colors, use a different pattern. They make foam safe paints, I think they are water based. Be careful not to add too much weight.
