RCU Forums - View Single Post - SHRIKE CLUB # 1
Old 11-09-2005 | 07:36 PM
piper_chuck's Avatar
piper_chuck
My Feedback: (12)
Default RE: SHRIKE CLUB # 1
Great idea for a thread! Here's my Shrike. It's powered with a rear exhaust K&B 3.5cc (.21 cu in). Has a Macs 3.5 tuned pipe. The engine is still fairly new, so I'm going easy on it. I've got it proped so it turns around 18,500 RPMs. I think it's got a 7x8 prop, but it could be a 7x9, not sure.
During construction I moved the firewall back about 1/2 inch to compensate for the extra weight. With the battery all the way back in the radio box, it balanced just right. I also replaced the spars with hardwood.
If you look very closely at the left wingtip you can see the antenna wire. During construction I installed a piece of pushrod tubing from the radio box to the wingtip so I could route the antenna through the wing.
Edit: weight is 2 pounds 4 ounces, 1020 grams.
