RE: Anyone converted 4-cycle gas string trimmer?
Balsa USA says the DVII should come out around 18-20 pounds......I am pretty sure that I am over that, not much though, I would say 21-22 lbs. The GX31 is a great motor, should be fine. Are you sure it will fit though? I would think an SE5 would have a very narrow fuse....my Dynaflite does as does the Balsa USA's that I have seen.
