ORIGINAL: sirsid27
I'll address this to anyone and everyone. After flying for 2 or 3 minutes if I let it get to far away I loose all control. Can't turn it, can't shut it down and it just flies away. I am just about to give up on this plane. I would be interested to hear if anyone else has had this problem.
Thanks, Sid
There are reports of that happening. How far away is it from you when that happens? Mine has kind of done that at about 40 feet away but I regain control somehow. I find that NOT pointing the end of the antenna at the plane helps believe it or not. Hold the antenna so the SIDE of it is towards the plane. Broadside to the plane.
There is also a mod for lengthening the antenna a little to extend range.
Done give up! The plane is WAY too much fun!!!!
Tom
