RE: Vectorflight Edge 540 build
I will second on the rudder servo arm.. You would get more mechanical advantage by moving it around 180. So how big of a hole did you drill right behind the firewall? I take it then you covered the hole with covering? After seeing that much weight was reduced i may just go ahead and do that. Then again i kinda dont want to take the time and move the servo in the rear
