RCU Forums - View Single Post - Car set up tips.
Old 11-11-2005 | 04:57 AM
  #34
J_Bone's Avatar
J_Bone
Default RE: Car set up tips.
ORIGINAL: HYPER7PRO!
hi all
thanks for the heads up gerwen next time i will write in lower case. i have a question what is the norm for the toe in and out on
1/8 scale buggies im not sure what i should set mine to as a base setup? and what fuel are you running grant?
thanks in advance
oh and im bringing it grant the question is are you
In the front, 0 to -1 is usually more than good. You would be surprised how many of the Pros have been running 0(parallel) or only -.5 of toe in the front. I use to run -2 until I was told to try a -1. It had the same cornering but was way more stable, especially at higher speeds!
