RE: 2-Pc wing conversion
Time to skin the fuse. First I have places all of my holes for my hard points in the foam filler that I made to patch the wing hole in the fuse. Instead of glueing both skins on at the same time I decided to put them on one at a time so that I can open up all of the holes before putting the other side on. After I sheeted the fuse and capped it off I glued in the hard points and the wing tube socket. Make sure that your socket is square with the fuse in all directions before your glue sets up. I left my socket full lenght to square it and then cut it off as close to the fuse as I could with out damaging the balsa and then sanded it flush.
