RCU Forums - View Single Post - Nother 27% CA 300L Build
Old 11-11-2005 | 09:54 PM
Steve's Avatar
Steve
My Feedback: (54)
Default RE: Nother 27% CA 300L Build
Eric,
Is that a low knife edge or a wind gust on take-off??? Looks like you did a real nice job building it too!!. I use a band saw to cut the elevators off of the stabs. Then I use a bench belt sander to true up the lines and make them strait. I will not cut the angles on the elevators until I get the rudder built and check deflection. Thanks for the heads up on that. I don't want any binding between the rudder and elevators.
