RCU Forums - View Single Post - Elevator Bellcrank Setup
Old 11-08-2002 | 04:07 AM
GPutt33's Avatar
GPutt33
Default Dual Control Horn Install
OK - Pic #4 and the last one. If you look you'll see all I did was slot a hole through the last fuse former for the center horn to work through. I will glue the ply squares that came with the Horn, fill it in around the edges, and then sand it all down smooth. I used a golden rod to connect to the center horn to go up to the servo. I am building two connecting rods approx 6 > 6.5 inches long to go back to the elevator horns. I am then running the rudder with a pull-pull.
I will post another pic or two later if you want when I have it pretty well complete.
