RE: Parkflyers Edge 540T
OK, thanks for the information and let me know when you have the pictures posted. I remember seeing them in your profile but there no longer there.
I checked the AMPS on the 12 X 6 prop with the 850KV motor. On high throttle it goes to 12 AMPS. The ESC is rated 18 AMPS, so I should be OK. I was surprised. I was expecting much higher amperage.
The 11 X 4.7 prop using the 1000KV motor went up to 15 AMPS. So, I'm a little intrigued by the 12 AMP measurement.
