ORIGINAL: Gordon_Dickens
Hi Ben,
I mounted one camera in the cockpit canopy facing forward and another on the rear bulkhead facing aft so I didn't need to use the mirror setup or the taped on mount that Scott Stauffer was using at the Super Jet South event. Both cameras are permantly mounted inside the airplane. I had to make a guide tube for turning the aft camera's recording mode on/off with the end of a 4-40 ball wrench whereas I am able to easily access the canopy mounted camera directly. I will try to put together a small writeup with photos on the
Georgia Jets website soon and I will put a link here afterwards once the writeup is posted.
FYI,
Gordon
Gordon
Thanks for the info. I look forward to reading the writeup when you post it.
Best Regards
Ben
