RE: Launcher variation
Hows this idea , if u cut a slot about 2"x1/4" where the pinhole is and put the ring (or a slightly bigger one) the one with the rubber tied to it down in the slot so u can put a smaller pin with a pull string through the ring to retain it from underneath , then just pull the string to release , u might have to angle the slot forward so the ring can come out easier ? ? ? ? ?
