RE: New chassis brace from ARO Products?
On the JT chassis I don't really see the need for a chassis brace. There is some flex in the chassis but not enough to be concerened about.
On the stock chassis there is allot of flex that should be addressed. I believe that the main reason for the flex on the stock chassis is because it is a 2 piece chassis. It would be hard to eliminate it without a complete top deck or some form of roll cage.
The JT chassis is longer than the stock chassis so 2 different parts would have to be made depending on which chassis is used.
Poor Judgment, if you are not using the stock batt/reciever box try bolting a piece of aluminum in its place to limit the flex. The chassis flexes a considerable amount more if there isn't any thing bolted there.
rolland
