RE: Extreme Flight 87" Yak 54 - Build & Fly
you say you can get 90 feet from the plane before it glitches, Is that with your antenna all the way down or one length sticking up?
I really think your fine. The fact that it glitches when you stand over the plane and touch the antenna is of no concern to me. (maybe you) If your going to be laying on the back of the plane and holding the antenna while flying, then I'd say you have trouble. If you like me and you stay on the ground, I think you'll be fine. Set the failsafe on your throttle to idle and listen for the engine to change throttle position while flying. I'm not sure if your servo leads and extensions are the twisted type, if they are not twisted, put a twist in everything. One twist per 2 inches in plenty, don't go to crazy
I think you pretty much confirmed that your reciever is fine when you swaped it out with other ones.
john
