ORIGINAL: Sturtz
Oh,,, and something I just discovered recently about the Futaba 7CAP. You can assign the seperate elevator halves after all.
It's done in the P-MIX and I'd be happy to explain it to you sometime. I'm still using the rev-Y-Harness for now but at least I know how to mix elev servos now.
Dual Elevetor - You are correct, but you can only use the subtrim and not the normal trim. I talked to Futaba and Bax on RCU. Not pleased about this. Let me know if you found different. If you use dual elevator in the p-mix then you can only trim the right elevator. Can you believe this? Unbelievable.
