RE: New to Mini-Z/IWaver micro scale
your best bet will be to start with a soft compound rubber, the lower the degree the tire the softer the compound example a 8 deg. will be softer than a 10 deg. so the 8 degree will have better grip. you might want to test them out and see what is going to work best for the track that you run.
