Concorde
Hey Eddie, Since you are around...On your DC-10 do you have negative down thrust in your turbines and how much. Also If you were to set the nose gear of the Dc-10 so the wing has 1 degree positive so the aircraft rotates easily then this of course would change the angle of thrust of the engines. Could you fill me in on what you did ?. Dean
