Shuttle Plus comments?
Komis
Construction on the Shuttle plus is very straight forward and easy since each part is done step by step. The parts are in seperate bags for each step on the way so you do not have to go digging for parts. Just pay close attention to the little hint boxes on each page and do not forget blue loctite on the bolts where needed on the instructions. Also be careful when you assemble the first part - the elevator assembly, the plastic is kinda weak and I accidently cracked it trying to get the rod pushed in.
