RCU Forums - View Single Post - Nexstar Engine Issues
Old 11-14-2005 | 09:48 PM
dolsen
Default RE: Nexstar Engine Issues
I think your problem is you are letting it idle to long and then guning the throttle. The motor will load up with fuel if left at idle to long and then when you hit the throttle it will start to flame out the plug. The next time you start it before you pull the plug igniter advance the throttle to half power to wet the pluh hot and clear out the motor.
