RE: Potensky Eagle vs. Parkzone Typhoon?
The only thing I am not sure of is how easy will be for me to get spare parts if needed.
Jeremy
[/quote]
If you refer to the plane - then only spare that is needed is thin CA with kicker and foam safe CA (oderless=smelless) for depron parts. If you can´t find a foam safe CA then use UHU por or 5 min Epoxy (or whatever Epoxy). I have crashed mine in horrible ways at least three million times and only things what are needed are glues and spare props.....It´s the depron parts that keep braking but can be glued every time (fastest way to fix is thin CA and kicker takes about 30 sec and you are ready to go again). Some might like to have some 5mm thick depron sheet to make new elevators (bigger ones) after serious crash - but once again, it can be glued in 5 sec). Get prop saver if you wanna fly in crazy way like me.
Reggae man
