ORIGINAL: BigWes
I would like to ask if there is anyone here who has shimmed their Nexstar's engine mount though. What did you use and what thickness of shims did you use? My measurements show about a quarter of an inch difference from one side to the other ----
THe Nexstar right thrust/left offset is designed to counter engine torque & spiral slipstream effets at ~1/3 - 1/2 throttle (training speed). At higher throttle settings it causes a right turn.
I have modified numerous Nexstars.
For a quickie fix I just slip a popsicle stick behind the right edge of the engine mount.
For permanent jobs, I invariably remove all right thrust & left offset. A balsa wedge is used to square up the firewall, & I glue it into place with CA. I then laminate either a 3/16" or 1/4" plywood layer on top of the shimmed firewall (depends what material I have at the time). Finally, I pin the new firewall from the sides (through the fuse) with #4 screws.
If I have removed the dihedral, &/or if I have sunk the wings into the cabin, I also remove some down thrust by wedging, before I laminate the top layer onto the firewall.
