RE: PT60 problem with parts fitting
Thanks for the responses guys. I have doubled check the plans many times (very obsessive compulsive) and every thing else lines up as it should. It seems as if the angle of the doublers is off just enough to cause a gap of about an 1/8". I think I will epoxy some wood to them and trace the pattern on them then cut to fit. Thanks again.
