RE: winter
Running in cold weather isn't any harder on an engine than running in warm weather if you get the correct operating temp. You may have to wrap the cooling head in tin foil tape or with a sock or something to retain heat.
As long as you can maintain operating temperature without running too lean, it'll work fine.
