RE: PT60 problem with parts fitting
When I did mine I glued the doublers so they were against the firewall and sanded the fuselage sides to match them. The previous posts are right about the plane building tail heavy. With a TT61Pro up front and the battery under the fuel tank, against the firewall, it still needed around 3 ounces on the bottom of the engine mount to balance.
