RE: Vindicator II
Hal,
Nice design, hope your maiden goes well. Looked through some of your earlier posts, found out its for 12lb thrust turbines. You can be sure many of us with smaller turbines are very interested. What are the span, length, approximate wing area, dry weight and kero capacity? What servos and retracts?
Where is the balance point/cg? For the maiden you might want to shift the balance point forwards about 1 inch from your calculated/empiracle cg location, just for safety. Nose heavy will probably be flyable, tail heavy may not be recoverable.
I'm also looking for something similar to build up for my MW44.
Best of luck.
L Turner
Brookfield, WI
